The guidelines say it's supposed to sit 1 finger width above the wrist bone but if I do that it just falls down loosely against my hand and/or it slides around so the screen is on the side of my arm. How do you keep it where it's supposed to be?
According to the instructions on my Charge 6, the watch should be raised to 2 fingers above the wrist while exercising. I tighten the band by a notch an push it up there. I use sweat bands and sweat towel to control perspiration near the tracker. So far, so good.
