02-05-2014 20:14
02-05-2014 20:14
My treadmill is set at at a 10% incline and burns calories at a higher rate than when it is set at no incline. By manually entering distance I get steps, but I don't know what my change in elevation would be to enter as a flight of stairs for a 10' change in elevation as if I were climbing a hill.
02-06-2014 02:06
02-06-2014 12:17
02-06-2014 12:17
Easiest solution is to find a high school kid doing trigonometry..... its a fairly simple calculation to workout the elevation change, but I can't remember how.... cos.. sin...alpha...d... its all in the past.
02-06-2014 12:27 - edited 02-06-2014 12:38
1. Divide the % incline by 100
for a 10% incline
10/100 = 0.1
2. Multiple answer by 5,280 (number of feet in a mile)
0.1 x 5,280 = 528 feet
So, with the incline set at 10% you climb 528 feet per mile.
So if you walked 2 miles at this incline you climbed 2 x 528 feet = 1056 ft...... 3 miles = 1584 .....
if you walk 54 miles you will climb the equivelent of Mt Everest!
02-07-2014 09:33
02-07-2014 09:33
If your goal is to increase your floors count, you're out of luck. If your goal is to more accurately reflect your calories burned, log the activity manually. (Increasing your floor count wouldn't affect your calories, anyway, I don't think.)
