01-23-2014
05:50
10:01
JuanJoFitbit
01-23-2014
05:50
10:01
JuanJoFitbit
How often do I have to charge the wrist band device?
Best Answer01-23-2014 08:04
01-23-2014 08:04
Which device? You can see the battery charge as of the last sync on your dashboard by clicking on the gear at the upper right...
01-23-2014 08:04
Best Answer02-05-2015 15:12
02-05-2015 15:12
I had Fitbit Charge before and it normally last around 7 days before I re charge it.
since I upgraded to Charge HR, I have to charge it every 3 days. Is that normal?
06:26
09:49
JuanJoFitbit
10-19-2015
06:26
09:49
JuanJoFitbit
when do you know you device is fully charged? mine has 5 dots flashing.
Thanks
Moderator edit: merged reply
Best Answer01-18-2016 02:13
01-18-2016 02:13
It would be great if the FitBit devices charged based on movement, like some watches.
01-18-2016 02:58
01-18-2016 02:58
That be Epic @adrianbau
Feel free to add your suggestions to the 'Feature Requests' Sub Forum, where users can vote, add comments,.. if there's a certain interest then there's a chance the developers pick it up and it'll be developed.
Tip: Search if the idea already has been suggested and add your vote / comment! ![]()
Feature Suggestions
URL: Click to go to the Feature Requests Forum
15:35
09:48
JuanJoFitbit
01-30-2019
15:35
09:48
JuanJoFitbit
I have a new slimbit it will not charge.
I can’t get my new one to charge
Best Answer05-11-2021 11:06
05-11-2021 11:06
Hi guys! I'd like to share this help article, which explains how to charge your Fitbit device and it also explains how to know when your Fitbit device is charged.
Finally, please check out this help page, in case the charging issue persists.
See you guys around.
Best Answer05-11-2021 17:47
05-11-2021 17:47
Best Answer05-12-2021 05:02
05-12-2021 05:02
@adrianbau Since you mentioned that the screen of your Fitbit device is not turning on, I'd like to know if you have restarted it as described in this help article.
See you later.
