I am a Physiotherapist. If anyone needs injury advice I am happy to help !
ANSWERED
If anybody is suffering from acute, sub-acute, or chronic injuries let me know. I am happy to offer advice and management strategies. If you are unsure what you are suffering from, write down the signs and symptoms and I will give you a diagnosis.
75 REPLIES 75
I completely agree with 1st response and posted a response to your letter a little ealier today.  hope all of your responses are helpful.
@Heybales wrote:
@SunsetRunner wrote:
I suffer from crazy shin splint pain. I think it shin slints what military doc said. It start with tighting and ache in the calf then the numbing starts in the toes, if I continue (which I do) eventualy the numbing will go all the way up to my knee. there were may days in my military life when i completed my PT test not being able to feel my legs.... forward to today and I walk only but the problem is still there. I wear calf compressions and still, stretch thoroughly and still. obvisouly if I walk at sighting pace I have no problem, but I'm trying to keep HR at cardio, since running is out of the question.
Wrong description of shin splints - which is what the name says - the shin, or front of the lower leg.
You got something different going on, so don't waste time looking up stuff on shin splints - with nerves going on, perhaps a compression issue in couple joints, foot could be due to tight achilles from tight calf, numbing on up could be from nerves coming from spine.
Usually those start at the spine and work their way down the leg though, not bottom up.
Hamstrings and glutes tight?
Can you touch toes while on floor legs straight?
If sitting in chair and an ankle crossed up to other knee, how tight are glutes when you lean forward and down?
I responded to your question  a few moments ago. I must have incorrectly posted as it doesn't show with your question.  You should find it a few comments down.  Best of luck!
@Heybales wrote:
@Beantowngurl wrote:
Hi I am curious what you know about sciatica. I am still recovering from
it, mostly when trying to sleep but it's still there after a good fast
paced walk too. It has hindered my active life but I'm getting back on
track now.
Does it ever really go fully away?
I've had bouts of sciatica, and good stretching and movement going again, it's gone away.
Had friends with worse reasons for getting it, disc issues, and it left some numbness.
Both cases bouts have returned.
It depends on how long the nerves were in the damaged state numb - never good - and your genetics and ability to recover.
I believe I worded it incorrectly, I do have shin splints the pain front of the leg. However, I was wondering if the numbing could also be contributed cause. I have been working on different strides during my walk to see which feels better. Oddly enough once the numbing kicks in and I stretch it out (sometime to stretch sessions) I am normlly good for the remaining miles.
Thank you for your response it gives me something to speak to my doc about.
I general do not cross my ankle over my knee unless doing a yoga pose (that is not comfortable for office)
Hammie glutes not tight during walk try to keep myself loose
Yes if sitting on the floor i can touch my toes
Again I want to stress I am not the physiotherapist that started this
post. I'm not a medical professional. My Dr did tell me that with shin
splints the pain does go away and people assume it's ok to continue working
out. I personally took 3 weeks off from walking etc. Iced my shins and
ankle area several times a day. When I resumed working out I continued to
ice every 45 minutes to an hour of excercise for about 20-30th minutes. I
know it sounds excessive but shin splints, again according to my Dr are no
longer thought of as a soft tissue injury but multiple tiny fractures of
the bone.
When I resumed working out I did baby steps re time , distance, speed and
incline. After 6-8 weeks I was again at a level that reached cardio and
was without pain. I do continue to use compression stockings most of the
time.
Check with your healthcare provider for any episode of pain. No pain no
gain is no longer my mantra. Hope this helps. Keep me posted. I would
like to hear what you learn and how you're doing.
Ok - so a mix of things going on - but shin splints is just the pain in the front.
If just walking a reason for them many times is how you land on your heel and how your shoes help or hurt. Some shoes have a very wider bottom tread that slants up to heel cup, and that includes off the back too, not just sideways.
When you use those muscles on shin to hold front of foot up they are under contraction of course.
If you hit the ground right (bad actually) with heel and your weight forces fore foot down fast lengthening the muscle while it's under tension (usually the foot will slap ground or close to it) - that's called eccentric contraction and causes the most damage to the muscle.
In weight lifting that's desired, as that's what causes the body to repair stronger and perhaps with more muscle. But that's for maybe 3 sets of say 15 reps, right.
Heavy body weight for 5000 steps is another matter. Hence once you've got it - how long you must wait to repair and get over it.
And if you've cause some pulling of the muscle away from the attachment at the bone (mainly upper pain), really bad. If running you could get the other reason of tiny fractures - but you are walking, and fractures isn't always the reason, nor the main reason for majority of people.
So examine your stride - if you take long ones, really landing on heel far out front, you are likely causing the above. Take shorter steps more frequently, this usually causes landing mid-foot automatically.
But wait until healed up - which requires time - forget ice at this point, you need blood flow to area to aid healing. Ice is right after the trauma to aid in swelling not so bad. If still swelling - that's body trying to heal - let it.
The ankle on knee stretch is for testing the glutes (just like hammy stretch) for tightness or to stretch - which some have a sciatica that goes through the piriformis muscle and if glute is tight, that usually is too - and a possible reason for sciatica issue causing numbing down leg. Which doesn't sound like your issue, but could be related.
Also allows seeing if both sides are equally tight, or lose, as the case may be.
What you might do is slow warmup walk - while doing that stretch achilles/calf with bent knee walking slowly until you feel no tightness, after doing that frequently during a 5 min warmup walk - calves may be lose enough.
Now, that stretch walk only stretches the soleus calf muscle, not the gastroc, which needs the straight leg heel off curb method to stretch.
Here's what you may do after the walk to help make sure you are ready for the next time, again after a 5 min cooldown pace.
http://drsunderman.com/soleus-muscle-stretch/
Help the next searcher of answers, mark a reply as Solved if it was, or a thumbs up if it was a good idea too.
That is great information thank you. Most of those stretches I do currently, but doing them during the warm up phase of my walk will have to try that - after my off days.
I am glad to learn about you as a resource for injury advice. The lateral ligaments on both my knees have been strained last month. I took ibuprofen to ease the pain and applied cold compress. I learned my lesson the painful way (upon resuming walking activity after resting only a couple of days) aggravating my injury in stepping up to board a truck. I now use a cane to reduce load on my knees. I am afraid this injury could develop into a chronic illness. Please advice. ( I will get back to the US January 2018 for professional medical help i.e. MRI). Thank you!
ARe you kidding?  You will diagnose and treat someone who you are unable to examine?  You'll know if the back pain is arthritis or a herniated disk?  A pulled muscle or a bone spur?  This has to absolutely be against any oath or licensing regulations you require.
I do think that is a bit harsh ... and rude. I have a number of advanced medical professionals in my family. They often times will make suggestions and give general advice to friends and family. I see no harm in that. However, they do not will not make a formal diagnosis with out examining the person in question. I read through the posts and it seems that it qualifies as general advice.
I do agree with you that if someone has a problem that does not go away, then going to see a medical professional to get a formal diagnosis is always the right thing to do.
I have heel spur that they said the only way that I would get relief is surgery until I found these shoes. I am not kidding. Have no more problem with my spur. My wife seen what relief I was having and she got her a pair we both work on concrete for 8 hours a day. We love them. I wish you would put more styles in wide. Thank you keeps up the great work orthofeet. I have 3 pair of the men's shoes and love them.
After a 6month break started back with walking on the spot every second day for about an hour, starting at about 5000 steps (an hour) and im up to about 7000 in just over an hour.  Today took my roommates godson to the amusement park and did about 11000 in 6hours.  Im not sure where to go from here. Monday is my normal next walking day but im really sore.  Do i do my normal 7000 on monday? Shoot for 12000? Take extra day off since i almost doubled my usual today? Im confused what to do.
0 Votes
Education of student, health of people & community service | gajera trust
We are dedicated to improving the quality of life for individuals around the India. From the education of students, health of people and community services
Quality healthcare and a great education is the path out of poverty
We think the path out of poverty begins when the next generation can access quality healthcare and a great education.
Gajera Trust focus on improving people’s health and child education
Gajera trust is focused on supporting three areas around the world - provide education services, health services and community services for society.
http://gajeratrust.org/Default.aspx
I have a lower back injury that has been very bad lately due to gaining so much weight from my pregnancy. I'm 4 weeks pp now and 40 pounds heavier than I was before I got pregnant so the pain is stronger than it was before. I can't lay flat on my back without it locking up and I haven't been able to lift as much as I used to without excruciating pain shooting up and down my back.
For exercises that require me to lay on the floor, how can I modify those so that my back won't lock up?
Heat and Massage.
Definitely chronic
 Im 48 and facing a 3 spinal fusion. I had my first lumbar fusion from L3 to s1 with , vertigo from Tbi from 2 wrecks. One by texting driver, second by a drunk driver. 2 cages, 8 screws and 2 rods LLIF then DLIF. Im post op 7 months inpatient high intensity rehab after 2nd surg to exted up to L1 so now 3 cages one extra large where L5 was however after my 3 month check up this week. I now have 2 broken distal screws at S1. I did have a slip but never hit ground caught myself like doing a wall stretch. Now possible facing fusion into pevis and im terrified. My Neuro wants me to only walk max of 3000 steps a day. Also diabetic type 2 so feet and legs stay numb mostly due to sever ner e damage and scoliosis. I refuse to dosurg where ibroke my neck. After this many issues with back, no way am i letting them work on my c2. Im good! However i just feel like if i do less than 3000 i will def hurt worse bc its nearly impossible to sit comfortably.  Any ideas on how to help the pain where S1 is but low impact. Rehab was total opposite,  we had to be serious bc i was where many college athletes go. Im just limited on what he wants me to do opposed to what hurts. I cant sleep in a bed so im just trying to get any ideas on movement.  I was extremely into sports through primary through High School. Whys a recommendation other than stretching. Im still very limber so he says thays good but says bc screws are broke to be careful.
Hi everyone, and a warm welcome to our new members.
Thanks for sharing your insights. It's great to see you here participating in the Health & Wellness board. While all viewpoints are valuable, to prevent any potential confusion or misunderstandings on this particular subject, I will be closing this thread to further comments.
Please note that we always recommend consulting your healthcare provider for any concern regarding your health.
Have a good one!
