06-24-2019 18:57
06-24-2019 18:57
I am very struggling using Fitbit when I forget to put the Fitbit watch on and off. I can't use them at work. I don't know how to set up the goal for that.
Best Answer06-25-2019 06:54
06-25-2019 06:54
Hi @purplemarie1980 Welcome to the forum. Let's start with a few questions, so I can better help you. What type of tracker do you have? What is the main goal you are trying to track (steps, distance, sleep...). Depending on your goals and when you plan to wear your tracker, you may want to set up your reminders to move during a limited time (perhaps in the evening after work).
08:41
13:20
LanuzaFitbit
06-30-2019
08:41
13:20
LanuzaFitbit
You should talk to a friend who can lead you on working together as a team. It will be my privilege to be a source of motivation for you
Moderator edit: Removed personal info
Best Answer06-30-2019 13:09
06-30-2019 13:09
maybe the watch version is not for you. maybe the inspire clip is better.
Elena | Pennsylvania
