Is there a way to stop fitbit from removing 1000+ steps?
it counts to 6000 , then i look again after a few minutes, it jumps back to 2000 steps, then back to 5000 then it will stop counting at 5100...
I carry my pixel watch in my pocket on the height of my thigh since that comes closest to a normal arm movement for counting steps. (Attaching it to my shin worked also very sporadically)
It counts very sporadically and its very frustrating.
1 REPLY 1
Hi @j1ades.  I moved your post to the Android app forum, a better fit for Pixel watch/Fitbit app issues.  I can't help you with your disappearing steps issue.
Just so you understand how this stuff works, a wrist device can undercount steps in general when you put it in your pocket.  You get different accelerometer patterns with your PW in your pocket.  Having it in your pocket is is the same as having it on your torso.  Some Fitbits have a setting for wrist/clip wear, but not the PW.  This doesn't explain disappearing steps.
Laurie | Maryland
