07-30-2014 11:10
07-30-2014 11:10
You just finished a fantastic walk. You are sitting in your living room, sweat pouring off you in sheets, and you quickly anticipate what your results will be. It winds and grinds and finally you get your results. It seemed like a solid 20 minutes of work and yet you see a lot of yellow lines and very few green lines and even less Very Active Minutes on your dashboard! Well -- here is why!
One scenario I will show you is walking to lunch. I go to the 5th floor at exactly 11:30, walk down the the first floor and across the street to the restaurant, then sit to eat lunch. I return to the office leaving at 12:20 and I'm back at the office walking the same amount of time and distance. Yet when I look at the results I have one yellow line and 2 orange lines. Why?
Because I began at 11:30 all of my walking in the 15 minutes it took to get to the restaurant was accumulated into that single frame of time. ( I think it was around 1450 steps ) The count in steps was a big woohoo to the application as I got a nice, yellow line. But coming back I was not starting my walk right at the start of a quarter hour. As a result my time got broken up into two different time buckets and the count per time bucket was below the trigger for active walking!
Active time is also measured this way but it is measured in 5 minute time buckets. So for that 15 minute walk, if I actually began at 11:32:30 then it will only count the number of steps that are in the remaining time between 11:32:30 and 11:35:00. From this point forward the measurement of your activity is all dependant on two or three things: how quickly are you taking steps, how consistently you are taking those steps, and how focused you are on making sure your steps pace is consistent. Then that block of time/counts is further cut up into 1 minute intervals to compute your active minutes. Now for me, I tend to get lost on the sights around me, the smell of the air, and thoughts about what I may go do tonight. As a result my pace is not exactly rigid!
You could vary your pace just a little bit and end up with a 5 minute block that is considered very active followed immediately by a 5 minute block that isn't. If you miss it by even 1 step it is not considered very active. And that is what the activiy window is displaying: how many minutes your step count happens to cross the threshold to be considered very active.
Now what I've found is this: if I take smaller steps, take them very quickly and maintain that pace with focused attention on just moving each step, I can get very active time up there. It seems to be around 3 steps per second. But I also find that when I'm walking at a comfortably brisk pace I actually sit around 1.5 to 2 steps per second. So think of a little wave moving below a line and that wave occasionally swells up then moves down for a while then moves up for a little bit again. Very active minutes, then is measured only when that wave blips up above that line. You can maintain it at that pace easier on a treadmill, but for enjoying the scenery and walking at your own pace you will waver your speed up and down based on many things around you.
So if you take a long walk, and you had stopped occasionally because your Maltese wants to smell a great bit of gossip from another dog, do not expect many green or yellow lines and even less Very Active Time!! But in the long run which matters more? What the graph says or what your body had just completed? 🙂
07-30-2014 14:45
07-30-2014 14:45
What matters most is what the body has just completed!
Your post was most appreciated. I am disabled so for me slow is very active and the days that I do much it still leaves me as not having been very active. The dog walking is the best example and is where I manage to get most of my steps. A clearer perspective is the result of reading your post; thank you.
07-30-2014 15:55
07-30-2014 15:55
Very helpful information, i was always wondering this that my routine is almost same everyday with almost same time breaks i.e. i go for coffee break almost at same same time for same duration of time, but still get so much of variations sometimes i get active minutes sometimes not.
Now i think may be because of 5 min buckets.
Best Answer07-30-2014 23:40
07-30-2014 23:40
Good info for people to understand.
As to changing stride to get the VAM - why not just change your stride length setting to something longer but very wrong so it adds up the distance quicker and gives you VAM time?
Same thing, right, fooling the system to reach a goal?
Best Answer07-31-2014 10:01 - edited 07-31-2014 10:02
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
