12-22-2015 13:15
12-22-2015 13:15
I don't walk much and typically get around via a scooter. I tried a fitbit and it kept thinking my scooter activity was walking...
I'm thinking I can still use it for heart rate monitoring, calories burned and activitiy minutes but, are those things impacted by steps?
Advice appreciated,
Sean
Best Answer12-22-2015 14:05
12-22-2015 14:05
@Ableman42 if you're looking at heart rate monitoring the Charge HR is the way to go. I own the Surge and while it has a few cool features, I can't strongly recommend it. Because of it's size and innacuracies with GPS.
12-22-2015 15:36
12-22-2015 15:36
I agree with the recommendation for Charge HR. You can hit the button and record an activity when you are not on the scooter. You can also subtract the time you are riding by creating a "scooter" activity. This thread explains how:
Best Answer12-22-2015 20:01
12-22-2015 20:01
I too vote the HR based on your interest beyond counting steps. You can also invest in a chest strap one that doesn't count steps at all. They run slightly less than a fitbit. I have one and I loved using it. And no, calorie calcs go beyond steps. You can use the stop watch feature that will generate data for a specific period of time not based on activity, but your HR.
Elena | Pennsylvania
Best Answer12-23-2015 06:19
12-23-2015 06:19
Thanks!
Are the active minutes calculated separate from steps or distance travel? I have alot of exercise I can do that will get up my heart rate but won't generate steps. More to the point I wouldn't want my activity minutes skewed by false step readings.
Best Answer12-23-2015 10:41
12-23-2015 10:41
yes, when you synch to the app or on line, it will show you your active minutes as a separate stat. as far as setting goals- not as detailed as you describe. you can set your goal active minutes to whatever makes sense to you- but that's about it.
Best Answer01-06-2016 07:56
01-06-2016 07:56
Best Answer01-06-2016 09:47
01-06-2016 09:47
I would have to say true. It will take into account all your movement and I think its most accurate when steps are involved.
Best Answer01-06-2016 11:30
01-06-2016 11:30
@Ableman42 wrote:
Thank you all, lots of advice. Let me see if I can ask it this way. True or false, none of the devices available track activity minutes or calories burned without including steps taken or distance traveled in the calculation. If false, which do? I don't walk much, and distance traveled in my scooter skews the calorie or activity minutes data. Thanks, Sean
What information are you interested in exactly? Are you only interested in calories burned without importance to everything else or something else? If you are only interested in calories burned, you could look into one of the devices with an HR monitor or just get a newer generation HR monitor that also measures calories burned based on body profile.
Also, depending on the Fitbit model you have, you can track calories burned over a period of time without needing to initiate an activity or exercise function. The basic increment value is calories burned by each 5 minute block.
Best Answer01-06-2016 11:38
01-06-2016 11:38
Best Answer01-06-2016 11:53
01-06-2016 11:53
You may be overthinking the calorie bit. If you burn more calories when using your crutches, then that will be reflected in your count. The same in that the fewer calories used when inactive will be reflected. As I mentioned, the Fitbit models with an HR monitor constantly tracks data whether active or inactive in 5 minute blocks. So you could always refer to that to get an idea of how many calories you are burning when not moving.
Even if you initiate an activity that is logged, you could always ignore the GPS and step data and focus solely on the calories. And if you don't want your device to think you are doing an activity when you are riding your scooter, you can disable that option in the settings.
Best Answer01-06-2016 12:11
01-06-2016 12:11
