06-21-2018 18:49
06-21-2018 18:49
I am looking to get my husband a pair of wireless earphones for his birthday.
Can anyone recommend a pair that and comfy and stay put when running?
Are the apple airbuds worth the money?
Thanks
Best Answer06-21-2018 19:13
06-21-2018 19:13
Hi @p_gets_healthy Fitbit Flyers are my all time favorite. They stay in, they are comfortable, and the sound is great.
Best Answer06-22-2018 00:48
06-22-2018 00:48
I have both the Fitbit Flyer and the Apple BeatX, which are very similar in design. Both are different from the Apple AirPods, which is what you may have had in mind and with which I have no experience.
I personally prefer the BeatX over the Flyer, mainly because I have small ears and the base of the ear bud on the BeatX is smaller than on the Flyer and therefore a better fit for my ears. I also find the part that goes around my neck to be more ergonomical on the BeatX than on the Flyer.
As to running, both work fine and stay in place, once you’ve found the right combo of tips and wings. No concern with losing them (because of the design), unlike with the AirPods.
Dominique | Finland
Best Answer06-22-2018 06:50 - edited 06-22-2018 06:51
Fitbit Flyer are a must, they stay in place and I have found no problem with them yet.
Best Answer06-22-2018 06:51
06-22-2018 06:51
I personally have good experience with Jaybird X3. I have not tried the Flyer as I already owned the Jaybird X3 when they came out, so I cannot give a review on them or compare them.
Karolien | The Netherlands
Best Answer06-22-2018 08:23
06-22-2018 08:23
@OnlyRunning wrote:Fitbit Flyer are a must
They’re OK, but not the only option. I personally find the BeatX more comfortable to wear.
Dominique | Finland
