10-14-2016 02:59
10-14-2016 02:59
10-14-2016 06:45
10-14-2016 06:45
Funny, @Skellibert! Start out slow and easy, don't injure yourself. Do some walking, increasing the distance and speed as you feel comfortable doing it. Then start out running slow and easy, a little now, and little more later. Soon, you'll be running and enjoying life.
10-14-2016 08:18
10-14-2016 08:18
Yep I agree you will get there. Takes time to build up.
Your doing great!
Wendy | CA | Moto G6 Android
Best Answer10-14-2016 15:09
10-14-2016 15:09
Best Answer10-16-2016 17:26
10-16-2016 17:26
@Skellibert I was never a runner- the joke with me was always if I am running you better too because something awful is about to happen. And then over a year ago I gave it a go. Of course by then I had walked, boxed, weight trained and other things. Running requires stamina. Keep trying, but do other things to improve cardio and strength. You have the right attitude.
Elena | Pennsylvania
Best Answer10-16-2016 18:08
10-16-2016 18:08
Best Answer10-17-2016 04:38
10-17-2016 04:38
I'd rather walk than run any day of the week, @Skellibert
Best Answer10-17-2016 10:50
10-17-2016 10:50
@Skellibert Good show! I've had a couple of times in my life in which I had to start from zero and the trick I learned was to take it very easy (running, jogging, walking or whatever), slowly increase the distance -- and I do mean slowly -- take a day off every now and then to let the body rest, and capture the data so that you can see your progress. That's where the motivation will come from -- seeing your results increase. If you're in the position to do so, make a table of distance vs date and build a simple Excel (or the equivalent) graph which will give you a pictorial view of how you are doing. If you are brave, pick an achievable goal and plot that on your graph and track your performance visually against that line.
Best Answer10-17-2016 12:00 - edited 10-17-2016 12:00
@garybartlett wrote:
...take a day off every now and then to let the body rest...
Just to expand upon that point a bit, while I agree rest days are important, not everybody needs to refrain from exercise on "rest days". Once a certain level of consistent exercise has been established, and your body has adapted to the more rigorous lifestyle, then a "rest day" might be backing off the weight, or the reps, or the per mile pace for a day.
10-17-2016 14:24
10-17-2016 14:24
@shipo My "rest" days are short walks with hiking poles, trying to restore the damage to my upper body from the myeloma. By short, I mean <1 mile with a long break in the middle. But it is very hard on my lower back and so that's a once-a-week event, all I can tolerate.
10-17-2016 15:47
10-17-2016 15:47
Best Answer10-18-2016 06:59
10-18-2016 06:59
To figure out your stride - count how many steps it takes you to cover a specific distance.
For example: If it takes you 10 steps to walk a distance of 20 feet (which is 240 inches) than your stride is 24 inches. (if my math is correct.) Now, that's a walking stride. A running stride is pretty much the same thing - but you may want to use a longer distance. I hardly think 400 meters is necessary though. Still, if you're going to run, if can't go 400 meters without stopping, at least you know that much and can work from there.
Best Answer11-02-2016 23:53
11-02-2016 23:53
Best Answer11-05-2016 10:11 - edited 11-05-2016 12:58
@Skellibert - If you are eating only "slightly better", and have "not changed my eating habits yet", does that mean you are not on a healthy diet? When you say your eating is almost always "under budget" and you are gaining weight, does that mean you are just counting calories? Consider healthier foods, if you haven't already - with less daily caloric intake if recommended. Just trying to think of what might help.
I re-read your posts, and it sounds like the exercising part needs consistancy. Assuming you are in shape to work out some - walk an hour each day; or schedule a walk/run/walk/repeat session 3 times a week; or skip rope (count 'em!) 40-100 repetitions several times a week (it dosen't matter if you get tangled up); or cycle every other day (use the lowest gear necessary to go up hills at first); or do a combination of these activities; or concentrate on one or two activities that you like the most; or try working out at a gym; or do cicuit training, or join an exercise class (heck, start one - the only requirement is that there are at least two people!). Not just once in a while, but from now on. Write down an exercise schedule and keep an activity log, or use one online. Get acclimated to sweating. Prioritize. Listen to music. Set aside a certain time of day to work out.
Realize that the hardest part can be motivation - join a group or find a buddy if you can. Getting used to exercising consistantly over time can take a few weeks or more to get better or to see benefits. Push through "relapses" (but never through pain or injury). Yes, take time off - but mosly for illnesses, emergencies, when life gets in the way, when there's a higher priority, or when you've "overdone it". That means that most days you are active, and only a few days are needed as rest days. You will soon find out that exercising consistantly can make you feel good afterward (even though you may be sore, achy, or tired at the same time).
I've assumed quite a lot here, so tell me to 'get lost' if you like - no problem. But maybe some things here could be useful to you, and that's all I was aiming for. Good luck!!
