10-30-2014 06:42
10-30-2014 06:42
If I walk in the morning my shins & sometimes calves hurt, pain goes away once I'm back home. Walking the same route in the PM without issue. I do stretch before each walk. Terrain is flat to mildly hilly equivalent of 1-3 staircases. I can walk on flat most of the way but it's 3 staircases down to the flat & 3 up to get back home. Building up to walk 5 miles a day, right now 3 + miles daily, it's easier to go out twice daily.
Why does this happen? Any suggestions for resolution?
Best Answer10-30-2014 12:55
10-30-2014 12:55
10-30-2014 12:57
10-30-2014 12:57
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
10-30-2014 17:46
10-30-2014 17:46
Sam | USA
10-31-2014 02:23
10-31-2014 02:23
I was also told not to stretch but to warm up before I walked or did any exercise. I usually workout on the elliptical before my usual workout, I'm not putting pressure on my legs because its a gliding motion not a pounding motion. Think of the muscle like a piece of meat that has been put in the freezer, if you try to bend it right after taking it out of the freeze it will break, if you get it to room temperature, it will bend more fluidly. When walking start at a slow pace then when you feel the muscles warm and relaxed walk faster. Good luck and have a great day.
10-31-2014 07:18
10-31-2014 07:18
Its now generally accepted that stretching before exercise isn't productive, and more likely to result in damage than help prevent it.
Like others said, your muscles are 'warmed up' if you walk later in the day, compared to first thing in the morning.
10-31-2014 09:10
10-31-2014 09:10
Thank you for your responses, I'll give your suggestions a try. If anyone has any other ideas, please add them to this thread.
Best Answer04-21-2015 20:30
04-21-2015 20:30
I'm sure this is age related as I can run freely afternoons but in the morning now especially as winter approaches in the southern hemisphere I experience stiffness and pain in all sorts of lower limb areas. So mostly I walk am and jog pm if time permits. Today I will be going to the gym for a class and have walked 5kms early this morning with a sore back...must have been twisted in my sleep.
Best Answer04-24-2015 08:44
04-24-2015 08:44
My suggestion is to reduce your miles to the point where you don't get shin splints and then start to gradually increase them. It can take a couple years to build up to big miles without pain. Along the way, most will probably experience some pains that will cause them to slow their progress.
At the early stages of each new pain, the solution is always to back off a bit on miles and increase them slowly.
