Water
Is there a water app reminder available? What are you using? Android App suggestions? Thank you in Advance 🙂
2 REPLIES 2
Hello @Evieee702
If you're asking about a Fitbit water reminder app, there isn't one that I know of.
There are several water/drink reminder apps available from the Google Play Store, including free ones with good ratings. You might want to check those to see if there's one that meets your needs.
Thank you 😊
