I did 3 sets of 10 bench press the other day and was near failure at the end of the last set. Yesterday I did the same amount of weight and only got through about half of the 2nd set before failure. Just wondering what might cause this. Other than decreasing the weight, what can I do to finish the set? I did finish the set once so it doesn't make sense that I can't do it again...
I'm not sure what would constitute a "weak" bench press. I find it best to leave the ego and judgement at the door of the gym. The goal is improvement, not perfection. It sounds to me like you're jumping in too quickly, and expecting too much, out of the gate. That said, here are some thoughts:
There are many good online sources of information. One I like is Athlean-X.
Good luck.
CharlesKn | Mid-Atlantic, USA
60+, strength and cardio
Charge 5, Android, Windows
