If I log running 2 miles does it add steps to my daily total? My reason for asking is that I was wearing my fitbit on my run. I know how many steped I had when I finishend and when I logged my run, it added more. Should I only log if I am not wearing the fitbit during activity?
Best AnswerYes, you only need to log running manually if you were not wearing the tracker while you were running - you can make a note that the activity was running without affecting the step count, if you wish.
Hope this helps
Craig
Best AnswerI would only log if you haven't worn the Fitbit during the exercise. The reason being is it alters accuracy of the tracker. If you run on a treadmill at 4 MPH, and sometimes at 2.5 MPH, then 4 MPH again, but you log in a total 4 MPH, it would be incorrect and remove your very active minutes and how many calories you truly burned.
