01-25-2014 06:23
01-25-2014 06:23
Do I have to log the activity in myself? I can spend and hour doing a workout and my cross fit doesn't show any active minutes.
Best Answer01-25-2014 09:07
01-25-2014 09:07
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
01-25-2014 09:07
01-25-2014 09:07
Sam | USA
01-26-2014 06:24
01-26-2014 06:24
Thanks! I will look at logging in my activities. I plan on staring Cross Fit full
time next week. I have the Fit Bit flex so it may be a bit different. Thanks for your help!
Best Answer01-27-2014 20:27
01-27-2014 20:27
I do crossfit and I getting nothing from rowing as much as there is hand motion involved. I don't get it.
Best Answer06-15-2014 08:48
06-15-2014 08:48
I row competitivly for a club we do cross fit as a warm up before going on the water. I hate that none of the excersise i do there is calcualated and i never have any active minutes on it becasue of that. You can manually enter the crew calories as there is a competitive rowing option but i am still not yet sure how i would enter the cross fit work out.
Best Answer06-16-2014 05:45
06-16-2014 05:45
@Dave16103 wrote:I do crossfit and I getting nothing from rowing as much as there is hand motion involved. I don't get it.
It's a pedometer. As @slysam said in her post, you will be much better off logging non-step based activities manually.
Best Answer06-16-2014 05:50
06-16-2014 05:50
@WeightUpton wrote: "...but i am still not yet sure how i would enter the cross fit work out." I would create my own activity and guesstimate the burn; or else use [Circuit Training] .
