Please explain the active minutes on the dashboard. I walked for 35 minutes on a treadmill this morning. I had over 4000 steps when I stopped 35 minutes later. My dashboard says that I had 4 active minutes. I thought it would be the time I spent walking. Please explain.
What you see on your Dashboard are very active minutes. These are harder to earn: merely walking is not enough, you have to walk fast enough. If you click on the + button of the VAM tile, you will see your active minutes split between: very, moderate and light. You need to select the ALL tab:
Dominique | Finland
