02-15-2014 16:26
02-15-2014 16:26
I would like to start swimming, can a fit bit be used?
If so which one is recemmonded?
02-15-2014 16:51
02-15-2014 16:51
The only model you can do this with is the Flex. But you also need to understand fitbits are designed to track step based activities, and your swimming will need to be manually logged anyway, to actually track calories, etc...
