fit bit scales
Hi has any one got the ARIA fitbit scales I am thinkig of buying them but would appreciate your opions cheers
6 REPLIES 6
I've had a Fitbit Aria since June 2013 and I like it very much. I'm using it once a day, always first thing in the morning. Granted, it's expensive, but as a Fitbit user, you pay for the convenience of its seamless integration into your Fitbit account. It's also good-looking, if aesthetics matters to you.
Dominique | Finland
I am trying to hook up my scales. It said it was, but its giving me a ERR sign no weight.
There's a dedicated help forum for the Aria scale. It's probably a better place to ask your setup question.
You may also want to check the help articles.
Dominique | Finland
So, do you feel that purchasing the Aria is beneficial to your goals and objectives in monitoring your Fitness?  I am considering purchasing that item.
Thank you
Well, it's just a scale, albeit a fancy one. In my case, I had a very old (25 years) scale that I knew wasn't terribly accurate. Therefore the Aria was a clear upgrade, especially since it also gives an estimate of your body fat and can automatically sync to your Fitbit account. If you already have an good scale, you can always enter your weight manually in your account. I like the fact I don't have to do this. I find the body fat % value useful, although I'm aware of the limitations of the method used by the Aria.
Dominique | Finland
What he said.
