02-18-2014 18:23
02-18-2014 18:23
Hi All
my heart rate monitar when I go to bed says I burn more then fit bit.
Has anyone found different , how do they track my heart rate when running or daily activites
Best Answer02-18-2014 22:16 - edited 02-18-2014 22:17
A HRM is meant for real exercise. Why would wear it to bed???
You should wear your HRM when doing real exercise. Its not an all day device. Fitbit is an all day device.
Also Fitbit is not a HRM either
Wendy | CA | Moto G6 Android
Best Answer02-19-2014 07:44
02-19-2014 07:44
Best Answer02-19-2014 08:22
02-19-2014 10:50
02-19-2014 10:50
Best Answer02-20-2014 10:40
02-20-2014 10:40
@WendyB wrote:A HRM is meant for real exercise. Why would wear it to bed???
I worn mine on a couple of occasions, and recorded my HR with two separate apps. I compared the results with the sleep pattern obtained with my Fitbit One. You can read about this experiment in this post.
I wouldn't do this every night, tough ![]()
The Basis B1 is an activity tracker that has an integrated HRM. It's designed to be worn 24 hours a day. Maybe it's what @stacer is using?
Dominique | Finland
