01-13-2014 18:37
01-13-2014 18:37
Best Answer01-13-2014 18:48
01-13-2014 18:48
Is it also showing as off on the website? Click settings, then click on your device while you are on the webpage. If it looks correct in one place, not the other, try to just sync the device.
