03-14-2014 03:10
03-14-2014 03:10
is there a way to add Herbalife products to the food database?
Best Answer03-14-2014 12:26
03-14-2014 12:26
They are there - I am on Herbal life too. Just put the food in just like you would on the Herbal life website, "Formula 1" you will see it pop up. The Formula 1 drinks are all I use so I don't know if other Herbal Life products are there. It is NOT under Herbal life. Hope this helps. Debbie ![]()
05-22-2014 12:46
05-22-2014 12:46
I'm a diabetic II and wondering if herbalife could help me to lose weight safe...
Best Answer05-22-2014 13:01
05-22-2014 13:01
Best way is to find a Herbalife Distributor in your area. Because she/he can meet you and give you answers to your questions on a 1:1 base. I am sure there is one in your area. Good luck, and i like to read your progress.
Regards, Martin Korevaar, The Netherlands.
Best Answer05-23-2014 18:26
05-23-2014 18:26
05-24-2014 06:06
05-24-2014 06:06
Hi @ChaesCreations - I think you will find the following link of interest:Is the Herbalife products safe for Diabetic
05-27-2015 13:05
05-27-2015 13:05
yes it can im a coach... it all depends of youe dite and if you are taking it the right way...
06-26-2015 00:23
06-26-2015 00:23
Hey,
Yes! Herbalife can help you loose weight safely, many people have done so sucsessfully and are continuing to enjoy Herbalife to maintain healthy weight 🙂
Kelly
