07-14-2014 20:39
07-14-2014 20:39
charging the flex. how long does it take to recharge
07-15-2014 00:01
07-15-2014 00:01
Chynda
My flex used to take 2 to 3 hours and my trick was i used to recharge it every 3 rd day
My force lasts 3 days for the same rule
Hope this helps
07-14-2014 21:17
07-14-2014 21:17
@chynad011 It depends on how low the battery is when you put it on the charger. Usually it's no more than four hours to reach a full charge.
Welcome to the forums.
07-15-2014 00:01
07-15-2014 00:01
Chynda
Hope this helps
