01-17-2014 12:51
01-17-2014 12:51
fitbit works well for walking running and eliptical, but not when i'm on a stationery bike or lifting weights.
Best Answer01-17-2014 13:07
01-17-2014 13:07
Because those are not Step based activities
I do put my One on my shorts legs to get some steps but its not accurate.
Weights you really do not walk that much. I know I dont. This is best to manually add.
Wendy | CA | Moto G6 Android
01-17-2014 13:12
01-17-2014 13:12
thanks for the feedback, which confirms that fitbit doesn't record your TOTAL daily activity; as you can burn quite a few calorie on a punching bag or weight lifting.
Best Answer01-17-2014 13:35
01-17-2014 13:35
Very few deveices record daily activity as such. Even for my MotoACTV you had to select the activity and then it just estimated the calorie burn based on height, weight, age, sex, duration, etc. You do the same by manually adding the activity to your fitbit acitivty record, which then adds the calories to your TDEE.
That is also the same thing you would do on other fitness websites. I use MyFitnessPal and used to manually log exercise. Nice things about the Fitbit paired with MFP is now a majority of my walking and running (step based activities) are automatically tracked. For Tennis, strength training, and other HIIT I just manually log it.
If you want more accuracy you will have to step up (no pun intended) to a more expenisve tracker and included a heart rate monitor.
01-17-2014 14:33
01-17-2014 14:33
did as you suggested, added 20 minutes on the stationery bike, only to lose the active time registered earlier for walking and the elipitical. can suggest what caused me to loose that information.
Best Answer01-17-2014 20:18
01-17-2014 20:18
If you use myfitnesspal also, and sync the two- you can log those activities into the fitpal, and it syncs 🙂
Best Answer01-18-2014 07:47
01-18-2014 07:47
Crystal,
thanks.
Best Answer01-19-2014 18:33
01-19-2014 18:33
Sam | USA
Fitbit One, Macintosh, IOS
Accepting solutions is your way of passing your solution onto others and improving everybody’s Fitbit experience.
Best Answer01-19-2014 20:40
01-19-2014 20:40
I've experimented w/the One, and it seems to only notice when it's moved side-to-side, not up-and-down. THat may be why. WHen you sleep, it's another thing, if I understood right.
