04-23-2014 09:47
04-23-2014 09:47
Is there a way for the fitbit to calculate this work out. It didn't register heavy excersize.
Best Answer04-25-2014 03:19
04-25-2014 03:19
You need to log this type of activity manually. Fitbits are step based and not good at picking up activity with added resistance. I have to log my treadmill separately, because the Fitbit doesn't capture the additional calorie burn when I add an incline.
I suggest creating a Custom Activity for this. There is no good choice in the drop down menu of activities to pick from. You can manually add your calorie burn -- if your machine gives you a read-out, your own HRM, or an on-line calorie burn estimator if you have neither of the other two.
Laurie | Maryland
