05-01-2018 19:21
05-01-2018 19:21
I suffered a bad concussion and a broken shoulder in an accident. Mostly because of the concussion I can not exercise or do much. Is it better just to not wear the fitbit? The doctors say at least 4 weeks of quiet is required.
05-01-2018 19:56
05-01-2018 19:56
Hi @2dogwalker,
If it's a Fitbit that has heart rate monitoring, I would probably wear it during the recuperation. The resting heart rate in particular can be helpful to gauge recovery. You can also use the Fitbit to make sure you don't get too much exercise, by monitoring your steps to make sure you're not getting too many. Best of luck and hopes for a quick recovery.
05-01-2018 19:56
05-01-2018 19:56
Hi @2dogwalker,
05-01-2018 20:37
05-01-2018 20:37
I do hope you have a speedy recovery. I'm sure you will be back to stepping when the DR ok's it
Do take care of yourself
Wendy | CA | Moto G6 Android
05-02-2018 21:48
05-02-2018 21:48
05-02-2018 21:51
05-02-2018 21:51
05-02-2018 23:37
05-02-2018 23:37
I hear you. I'm pretty active but have had to slow down myself. Its hard
05-04-2018 19:40
05-04-2018 19:40
@2dogwalkerTake care with your recovery... In Australia we are having a spate of sport football concussions. They are sidelined for weeks now, because the medical profession is also treating well retired sports people now suffering memory issues etc..as a result of concussions in their playing careers..Back then they hadn't realised the ramifications of no rest etc..
If your Fitbit is a HR tracker I would be wearing that 24/7 to monitor your recuperation as @WavyDavey has suggested.. Here are my results for the last 5 months. I had observed since Fitbit released these trackers that I could track the onset of illness. For example in the image below my strep throat symptoms hit me 2 days after the RHR started going up.. Clever nature.... wants to spread the illness.
The incorrect medicine at the start was a disaster, I could hardly walk with cramps in my calf muscles.. I have always been pre-hypertensive 135/75, my blood presure had spiked and my GP was away and the other clinic GP was cautious and changed my medication...... and... the fall where my sleeping HR spiked for the evening.. during the day I was progressively feeling lethargic and cold...
I always plot my average sleeping HR because Fitbit really stress to get an accurate RHR you should wear your watch while asleep. As you can see the Sleeping HR follows the RHR.
Again take care in your recovery because there will be plenty of time to catchup like @WendyB and me, where we are overcoming issues....
05-04-2018 21:03
05-04-2018 21:03
Thanks for the advice. I do wear my fitbit to bed because I am a sleep walker and if I wake in the AM and have 1000 steps, I know I have been sleepwalking. I do have alarms on my doors that hopefully will alert other in the house if I try to go outside.
I think the concussion is giving me more problems than the broken shoulder. The therapist has given me helpful hints on turning by staring at an object and when my head turns, follow the object with my eye, and when it is out of sight, to pick another object to look at and complete the turn.
Also limit screen time on computer and TV.
05-04-2018 22:16
05-04-2018 22:16
@2dogwalkerWe are here, even miles away, and don't hesitate to keep in touch with your progress.
All the best again in your recovery...
05-07-2018 21:45
05-07-2018 21:45
05-07-2018 23:00
05-07-2018 23:00
@2dogwalker Good that your on the way and better still that the specialist has a wait and see..
My neurosurgeon is like that.. and mild exercise has cleared all of my lower back issues. I'm now restricted to only 7lb/3kg per hand when carrying shopping and tightening up the core when I move/lift other things. Age related wear and tear. Also occasional acupuncture and physio..
