Does anyone know how Fitbit measures steps in terms of calories? Does it know if I am doing 2000 steps in a museum or if I am doing power walking?
Thanks
it knows number of steps, distance, time. If you have an HR feature it knows that. All of that works on an algorithm that gives you calories. If you have the HR is closer to actual.
Elena | Pennsylvania
Great question - thanks for asking it.
Even the older Fitbit One has a "3-axis accelerometer" (taken straight from the specs😞 this is what allows it to know the difference between slowly strolling in a museum or power walking. Active minutes are also granted based on the intensity of your movements (= you need a certain number of steps each minute in order to get them). How this is done "under the hood" is as mentioned by @emili, using a clever algorithm.
Dominique | Finland
