12-30-2013 10:04
12-30-2013 10:04
I am trying to track my blood pressure here: http://www.fitbit.com/bp - it lets me make an entry and gives me a finding (say normal) but if I try to enter previous entries (I would like to graph them) the one entered previously does not seem to stick. Is that the way it is supposed to work or am I doing something wrong?
On a Macbook Air using Chrome.
Best Answer12-30-2013 14:47
12-30-2013 14:47
You'll have to choose the previous date for each entry; there's a drop-down at the top of the page where you can select the date for each entry.
Best Answer01-01-2014 10:28
01-01-2014 10:28
I do not think that is the case. Check out this screen shot: http://note.io/1dU6mGd
Note that it shows nothing recorded but the graph looks like it has????
Best Answer11-06-2014 12:11
11-06-2014 12:11
Why won't you intergrate the Withings Blood Pressure Monitor into working with the app WITHOUT having to MANUALLY enter the data?
