12-06-2016 17:25
12-06-2016 17:25
Hi all, My daughter and I do a lot of indoor wall climbing and would like to know what is the best fitbit for this. The average height is approx. 11mtrs. It would be good to know heart rate, calories and ascent count. Maybe some sort of setting for difficulty.
Any help is a help.
Thanks.
Jay.
Best Answer12-08-2016 04:51 - edited 12-12-2016 09:29
Good morning @JayWard, it's great to know that you want to expend time with daughter, indoor wall climbing sounds a perfect time to share. I think that you can definitely consider Fitbit Charge 2 and Fitbit Blaze, both track heart rate continuously in order to give you a better understanding of your fitness level. Calories information is personalized since the Fitbit Account takes in count your BMR (Basal Metabolic Rate), plus your activity information. ![]()
You have also the Surge which is a good option if you're very active. Take a look of this page, so you can compare them. You might also call Customer Support as @GershonSurge mentioned. ![]()
Good luck and welcome to the Forums! ![]()
Best Answer12-05-2016 14:44
12-05-2016 14:44
Hi all,
My daughter and I do a lot of indoor wall climbing and would like to know what is the best fitbit for this. The average height is aprox. 11mtrs.
Any help is a help.
Thanks.
Best Answer12-06-2016 17:43
12-06-2016 17:43
I recommend calling Fitbit. Their sales reps are quite good.
