Is there a way to change the associated calories on the tracker? If I each 1/2 of the yogurt, which is 60 calories, I would like to be able to enter "30."
My suggestion would be to create your own custom foods, so you can add the calories you are seeing on the label. On the Fitbit App, in the Food Log, Log Food, select custom, then you can manually add the food name, brand, service side, calories, and so forth.
Thank you for this suggestion...I have tried to alter the amount 1/4, 1/2, etc...it doesn't result in changing the count. Peanut butter listed as 613 cal for 1 tbsp...I checked the label and 1 tsp was about 170...no matter what quantity if changed, the calories, didn't..
