04-13-2021 15:34
04-13-2021 15:34
I was trying to work out how many calories was in 60 grams of dried basmati rice (Tesco's brand) but when i scanned the app every brand of basmati rice has a completely different calorie result I'm really confused nothing matched my packet in hand and the generic cooked basmati of 220grams also doesn't match calories in any of the other branded at the same weight. Fitbit also doesn't tell you if it's the raw calories or cooked calories for half the brand's on there. I hope this makes sense.
04-14-2021 08:52
04-14-2021 08:52
I was curious about the calories because I'm eating basmati rice, too. Tesco's basmati rice according to their website is 359 kcal per 235 grams of rice.
That comes out to about 92 kcal for 60 grams of rice. Let me just say I'm not a great math guy but this might give you an idea of how many calories.
04-14-2021 12:39
04-14-2021 12:39
Yes I worked out the calories via the packet but compared to the apps standered cooked basmati rice which says 235g of cooked rice is 284 calories which compared to what we both saw for Tesco's for 235g cooked rice I don't understand how the difference is so huge.
04-14-2021 13:27
04-14-2021 13:27
04-15-2021 04:04
04-15-2021 04:04
Hey cheekymonkey, I just looked at Fitbits calories for Uncle Ben's basmati rice, it says 150 cal. per 1/4 cup. I Googled Uncle Ben's basmati rice and it says 220 cal. per cup. Oops. Looks like Fitbits data is a bit skewed for the rice. Have a great day.
04-18-2021 12:45
04-18-2021 12:45
if there is nutritional info on the package, use that always. There is a difference in how things are preserved so the most accurate info is from the manufacturer. I agree to just add the info for your meal. You always want to start raw with your calories. If you are adding things you want to add them as their own packaged calorie info. For example, a cup of fat free broth is 5 calories. If you cook your rice in that instead of water, add the calories to your total for the portion you made.
Elena | Pennsylvania
04-19-2021 03:51
04-19-2021 03:51
What @emili said plus throw away cups and weigh properly your food.
