04-17-2023 04:26
04-17-2023 04:26
Hello
Will you be fixing the food logging section?
Recent food on app is all over the place, liked food won't go from app when I remove it from the dashboard.
It's getting frustrating.
Please offer some solutions!
Thank you
07-23-2023 20:54
07-23-2023 20:54
Ensure that you have the latest version of the app installed on your device. Developers often release updates to address bugs and improve performance. If the app continues to behave erratically, try clearing its cache and data. Doing this can help remove any temporary files or corrupted data that may be causing issues. Visit the app's website or support page to check for any known issues or bugs that other users may have reported. This can provide insight into whether the problem is widespread or specific to your device.If the issue persists, consider reaching out to the app's support team directly. They can provide personalized assistance and may be aware of a solution or workaround for the problem. If you find that the app's food logging feature is consistently problematic and support hasn't been helpful, consider trying out alternative food logging apps that are known for their reliability and positive user reviews.
