02-07-2015 19:41
02-07-2015 19:41
Best Answer02-14-2015 05:39
02-14-2015 05:39
One of my favorite ways to prepare tilapia is to mince up some chili or jalapeno peppers and shallots. Mix the shallots/peppers with a squeeze of lime juice and butter (or coconut fat if you are avoiding butter). Work it into a spread and smear on top of the fillets before cooking. The butter/fat will melt away and leave the shallot/pepper mix on top.
Best Answer02-15-2015 12:25
02-15-2015 12:25
I eat talapia at least once a week and all I do is put in baking dish cat with olive oil on both sides and i season with Morton Nature's Season blend and paprika then bake for about 20 mins at 375. Simple but tastey to me and the hubs.
Best Answer02-15-2015 15:30
02-15-2015 15:30
McCormack has a spice pack for tilapia that is just delicous. And I don't like fish either.
http://www.mccormick.com/Recipes/Main-Dishes/Recipe-Inspirations-Mediterranean-Herb-Crusted-Tilapia
Best Answer02-15-2015 15:32
02-15-2015 15:32
This isn't one of the fish you mentioned, but my other go to fish recipe is this one for salmon in Puff Pastry:
http://communitytable.com/31660/kevinmckidd/kevin-mckidds-salmon-in-pastry/
Best Answer04-15-2015 16:27
04-15-2015 16:27
I didn't like fish but I found a delicious and simple recipe.
1 Tilapia
2 bay leaves.
oregano
lemon juice
salt and pepper.
On a piece of foil put the Tilapia and all the ingredients together, cover everything and put it on the grill for 5 minutes each side. Simply delicious!
Best Answer02-10-2016 10:01
02-10-2016 10:01
I LOVE doing baked salmon in foil...fresh squeezed lemon juice with some dijon mustard and garlic mixed together and spread over the top, topped with lemon slices ... makes a very moist and delicious fish. I imagine this would work for the fish you mentioned.
Best Answer02-14-2016 17:11
02-14-2016 17:11
@Maithuna- some of the fish on your list are more oily and fishy than a new to fish person may find yummy. I would talk to your fish counter person about which ones are more suited for you. Talapia is one of the mildest so you should start with that. Haddock is primarily used in breaded or tempura recipes so if weight loss is a consideration you may want to skip that one. you can for sure prepare it other ways, but I don't know if it will be as tasty. the other one is salmon. easiest to cook and eat. flounder too.
Elena | Pennsylvania
02-19-2016 10:48
02-19-2016 10:52
02-19-2016 10:52
@HelenaFitbit Have you tried seared tuna? My new favorite - and it doesn't taste fishy at all. I've made it myself and also the one they sell at Outback Steakhouse is delicious (and it's in the appetizer menu, so the portion is small.)
Best Answer02-23-2016 13:38
02-23-2016 13:38
I just had the best salmon dinner ever and I had to share. It was based off of this recipe: http://www.health.com/health/recipe/0,,10000000521971,00.html
I cooked the fish in a little bit of oil, 4 minutes or so on a side. Meanwhile I mixed Harry and David's Charred Pineapple Relish (my new favorite thing) with a shallot, some rice wine vinegar and cilantro. After the salmon was cooked, I served it with the relish. So delicious!
Best Answer04-20-2016 20:32
04-20-2016 20:32
Best Answer04-21-2016 22:03
04-21-2016 22:03
Thanks for the fish recipe in parchment paper. I cook cod and salmon with this method all the time. It's great when camping also. I have a problem keeping the paper folded so I have started stapeling the ends together.
Best Answer04-22-2016 08:33
04-22-2016 08:33
Marinade Salmon in soy, ginger, honey (or agave) and some garlic; toss in the oven for 20 min on 400 and serve over brown rice with some brocoli ( we prefere baby broc) and you have an amazingly tasty dinner. Enjoy!
Best Answer04-30-2016 14:47
04-30-2016 14:47
I just did a new salmon recipe cooked in foil with "firecracker sauce". I used Frank's Red Hot Sauce and this recipe: http://littlespicejar.com/firecracker-baked-salmon-in-foil/. I recommend it if you like spice.
Best Answer05-01-2016 12:14
05-01-2016 12:14
If you are a picky eater already and didn't like fish last time. I would not even advise you to use a recipe.
Try to prepare the fish as you want to ! For example, fry it, use some vegetables you think that would suit the meal and some sauces that you think would suit.
Best Answer05-05-2016 12:24
05-05-2016 12:24
Hey @Maithuna I think that one of the fastest ways to cook a delicious fish is some lemon juice, olive oil and your favorite spices, you just do a wrap in foil and put it into the oven.
Easy, delicious and healthy! ![]()
Was this what you were looking for? Vote for it and mark it as an Accepted Solution!
05-17-2016 14:45
05-17-2016 14:45
