04-15-2015 13:32
04-15-2015 13:32
Today I entered "green beans" and got a list of processed, canned and frozen. I added "fresh" and got a list of processed beans with the name "freshlike!"
I Like your tracker and find it easy to use and speedy BUT really all foods should have a plain, fresh option- because ultimately that is the best way to eat them.
What do you suggest?
04-15-2015 14:43
04-15-2015 14:43
Try using "raw" instead of "fresh". It helps me. Also, as long as the frozen vegetables are no salt added, the nutrition should be the same as fresh.
Laurie | Maryland
04-15-2015 14:54
04-15-2015 18:29
04-15-2015 18:29
thanks ... that is a good idea. I'll try that.
04-28-2015 16:44
04-28-2015 16:44
@PKD3 If by any chance you don't find a food from the Fitbit database, you can add a new one to your list and manually input the nutritional information. Bon appétit.
04-30-2015 09:22
04-30-2015 09:22
Yes this is correct and if your are like me that I don't know the calories of some raw foods etc. I quickly look it up on google and add it. Even if it's not on the dot aleast i have an idea. I like that after you entered a food, you can find it in your frequent, recent or custom tabs, saves time. The begining I think has been the most time consuming entering meals and snacks.
