Most recipes will have the number of servings it makes. If its 6 then you divide it into 6 servings.
If liquid usually a cup is a serving.
Wendy | CA | Moto G6 Android
I’ve just tried to add olives to my app and it says one serving! I mean how many is that 1 or 5 ? It’s confusing
@louweight15 Look at the can itself. It will tell you the serving size
Hi @louweight15! It's good to see you visiting the Community for the first time.
A standard serving size is about 75g or: ½ cup (with vegetables), but I'm guessing this could be different with olives. Were you able to find the recommended serving size on the can itself like @WendyB mentioned earlier?
