10-21-2021 16:25 - last edited on 11-04-2021 11:38 by MarreFitbit
I love the barcode scanner in the FitBit app., but I was surprised to see that it doesn't recognize alcohol. As someone who consumes a fair amount of alcohol, I would like to see a software update to reflect this.
I can't be the only one who's not pleased with this omission.
A Google search didn't yield any results either. I would think that alcohol is high in calories, but....I haven't been able to verify exactly how much. Can someone point me in the right direction?
10-22-2021 00:21
10-22-2021 00:21
You might want to vote for this feature suggestion:
https://community.fitbit.com/t5/Feature-Suggestions/Tile-to-track-alcohol-intake/idi-p/3211563
It's been around a while but doesn't yet have many votes. It's not exactly what you are suggesting but might be enough. Hopefully with some more Fitbit may consider it.
10-22-2021 00:21
10-22-2021 00:21
10-22-2021 09:25
10-22-2021 09:25
Thanks for the feedback. I just posted in that forum. Thanks. 👍
11-10-2021 03:50
11-10-2021 03:50
@SteveH Thanks for sharing that suggestion.
@SunsetRunner You might consider manually log it, calories depends on brand and amount but you can take the information from the can.🙂
