03-20-2023 04:18
03-20-2023 04:18
I cant add a recipe I make?
07-17-2023 19:28
07-17-2023 19:28
I did, I am on Ketovore and converted my own home made recipe for Meatloaf and it's half and half pork/Beef with ground pork rinds as the breadcrumbs and eggs with spices pepper and salt. I made a big batch from 5 kg of meat and calculated the ingredients and nutritional data. Then indicated in the title of the food Home made etc... and what 100 grams would calculate to. It was lots of work but you only needed to do it once. I've also done it for Home made soup, and home made bone broth. I pretty much ignore the calories however I'm extremely low carb and that's my main concern. I also do intermittent fasting and head that up also as Fasting in the title name of the food and apply 1k/cal in the nutrition section or it won't save.
Best Answer07-25-2023 02:40
07-25-2023 02:40
I am frustrated by the same. Can custom a meal in the webpage dashboard but I want to do it in the app as this would be much easier and quicker. Is it possible to log a custom meal in the app?
01-26-2025 17:14
01-26-2025 17:14
Agreed - I used to be able to do it on the website dashboard but they discontinued the online site - frustrating!
Best Answer02-09-2025 23:09
02-09-2025 23:09
To add a homemade recipe to your food log, start by creating a custom recipe in your app. Most food tracking apps allow you to manually enter ingredients. Simply add each ingredient and specify the quantity. Once added, some apps will automatically calculate the nutritional information based on the ingredient list. After saving the recipe, you can log it in your food diary by selecting it from your saved meals or entering the serving size. If you're using an app like MyFitnessPal or Lose It!, the process is pretty straightforward!
