How do you log homemade food or enter a recipe to frequently use in the food log area? The app seems to only use barcodes.
Google says to go to Fitbit.com, not the app. Fitbit.com says only use the app after this summer.
Ultimately, trying to avoid tediously entering every single ingredient for a meal every time I have leftovers. Thanks in advance!
Add Custom Food only allows you to enter known nutritional information- which is not readily known for homemade meals. This does not allow you to enter the components for a homemade meal.
The Custom Food on Fitbit would mean I’d need to look up all individual ingredients’ nutrient information somewhere else (for each onion, garlic clove, etc), then calculate all this, and then enter it under Custom Food on FitBit.
Most food trackers have a means for you to enter a homemade meal (enter the onions, the garlic, etc) as the components for the food tracker generate the calories you’ve consumed. Is this feature available? It doesn’t look like Fitbit allows you to do much more than scan barcodes of premade food.
I think the feature of grouping foods to make homemade items is not available. Honestly you probably would not want to do so anyway. If you want to track anything other than calories, protien, sodium, and maybe fat the database is horrifically incomplete. You probably would want to look elsewhere for a foodtracker.
Potassium for example is a hot mess. So many fresh grocery ingredients just have a - for potassium when they are a major source of it. For example fresh spinache, potatos, and strawberries. I have zero faith the vitamin count is any better and you can't even enter that info for homemade items.
I'm sticking with the FB tracker for now, but I'm manually entering custom nutrition for many items. For recipes I make often, I'm using a tool such as the myfooddata recipe nutrition calculator and logging the overall nutrition from there
Best AnswerYou used to be able to enter a home made recipe on the website, where you can also enter your daily food. Yes it was a **ahem** as you needed to enter each ingredient
Now it doesn't seem to be available which is USELESS when we are supposed to be cooking from scratch and not having UPF
This used to be available on the website access to your account. BUT when Google took Fitbit over it was dropped. Soooo inconvenient
Best AnswerI'm hoping the new Fitbit AI allows you to just take a picture of food for it to give you the best guess for calories and macros for custom entries
The nutrition section is not on the new preview yet however, so time will tell
