How to correctly log food?
ANSWERED
I'm having some trouble here, should i type on every product if its cooked or not? for example rice? Should i do it like 200 grams white rice - cooked, thanks in advance
1 BEST ANSWER
Accepted Solutions
@Monstrum
Fitbit is aware of this problem and working on a resolution. Note that the unit of measure and nutrition information is correct in the database, it's simply displaying the wrong unit of measure on the log.
Hope this helps!
SebringDon | Florida USA | Fitbit's Food Plan Demystified
Charge HR, Flex | Windows 10 | Android | iPad
3 REPLIES 3
In this case, it is best to measure and log the food after cooking it. If you weigh in a dry cup of rice, it will be a huge amount to eat after being cooked, same way with meats (since they lose water when they cook), pastas (they expand) or sauces (just your portion).
As a personal recommendation, make sure you write down your meals as soon as you are about to get them; this will prevent the moment where you are holding your food log and remembering how much you ate and underestimating amounts.
I have a tiny notebook where I write down the meals and their weight, so when I'm ready to write them down, they are accurate. Smiley Happy
Get a food scale and measure everything. Increase your water intake and find different sources or variations for the meals you love that won't take a hit on your caloric budget.
Hope this helps! Let me know if you have any questions Cat Very Happy
Fitbit Community ModeratorHelena A. | Community Moderator, Fitbit
Was this helpful? Yay! If it was, please vote for it or mark this as a solution. Show us!
Another thing that I can't seem to figure out; I log everything as Grams, why does it show like this in cups and other stuff when I've selected grams:
@Monstrum
Hope this helps!
