12-20-2020
10:20
07:13
WilsonFitbit
12-20-2020
10:20
07:13
WilsonFitbit
Is there a way to look back at what I was eating several months ago? I lost several pounds then and need to get back to whatever I was doing.
Best Answer12-22-2020 13:22
12-22-2020 13:22
Hi @fitmaggie
Using the Fitbit dashboard on the computer, click on the Log tab, next click on the Food tab, then there is an arrow to view prior days or you can select a specific date using the select date option.
I hope this helps 😊
Best Answer01-28-2021 07:12
01-28-2021 07:12
Hello @fitmaggie Welcome to the Community Forums! @cathm It's great to see you around and thanks for your input!
I was able to see that @fitmaggie provided information about your inquiry. Was this the answer you were looking for? If it was, I recommend marking the answer given as the best answer. By doing this, other users with the same inquiry will be able to find a faster response.
Additionally, you can get more information about how to track food here.
See you around.
