02-27-2019 04:09
02-27-2019 04:09
I connected the Lose It App with Fitbit. I log into Lose It. Then I log into Fitbit or vice versa.
Either way Fitbit records my food log twice. I thought with Lose It it would log automaticallly in Fitbit.
I don't understand how it works. Please help. Thank you.
Best Answer02-27-2019 14:11 - edited 02-27-2019 14:14
I am also confused. You said you logged at Lose then then you signed into Fitbit. Did you log there as well?
Only log one place. At Lose it. But it does take time to be brought over. Your devices also needs to sync
Disrequard
You need to go to Lose it and connect them
https://www.loseit.com/#Apps%20&%20Devices
Then it will be brought over once it syncs
Wendy | CA | Moto G6 Android
