07-29-2021 06:09
07-29-2021 06:09
Can Fitbit count carbs instead of calories?
 Best Answer08-13-2021 07:38
08-13-2021 07:38
Hi @Cenie - I also count carbs but I use the Atkins app to record my food since it is mainly focused on carbs. Atkins will sync to Fitbit. Basically, you would login to the Atkins app … Find the section for connecting another account. This section is often called "Apps" or "Connect" … follow the instructions. Eventually, it will prompt you to login to your Fitbit app to complete the process.
Good luck! How how you doing?
08-05-2021 10:52
08-05-2021 10:52
It doesn't necessarily count carbs, but you can see you carb totals when you go into your food log. If you log everything you eat, it provides a break down of carbs, fat, fiber, protein and sodium intake. I do low carb and count calories and it is a very beneficial tool. The desktop version shows the fiber. The phone app shows just the fat, carbs and protein.
Hope this helps!
08-06-2021 10:08 - edited 08-06-2021 10:09
                                          Community Moderator Alumni are previous members of the Moderation Team, which ensures conversations are friendly, factual, and on-topic. Moderators are here to answer questions, escalate bugs, and make sure your voice is heard by the larger Fitbit team.  Learn more
Hi, welcome to the Fitbit Community forums, @Cenie.
Thank you for sharing your inquiry about carbs.
As @Singer419 mentioned earlier, you can see information for carbs in the Macronutrients shown on the Fitbit app, along with fat, fiber, protein and sodium intake, but there is no carb carb tracker in the app or the devices.
However, this idea has been posted on the Feature Suggestion board of the Community and it is currently Under Consideration status as you can check here. Make sure to add your vote and comments as well, since this section is constantly reviewed by the team of developers.
Hope this helps.
08-13-2021 07:38
08-13-2021 11:30
                              08-15-2021 22:15
08-15-2021 22:15
Thank you 😊 I will try that.
08-24-2021 16:41
