01-29-2019 16:39
01-29-2019 16:39
If whatever I am consuming does not appear in the list of foods is there any way I can just enter the known nutritional values??. Many thanks, Bruce
Best Answer01-30-2019 01:23
01-30-2019 01:23
Hi Bruce,
You can click on 'create new food' on the right side and then you can enter all the nutritional values yourself!
01-30-2019 01:23
01-30-2019 01:23
Hi Bruce,
01-30-2019 04:46
01-30-2019 04:46
Best Answer01-30-2019 05:00
01-30-2019 05:00
@Ridb: if the suggestion you got from @Eliseee solved your problem, consider marking her post as a solution (this will benefit other users with the same question later on), as well as giving her credit by voting for her post.
Dominique | Finland
