01-26-2016 07:37
01-26-2016 07:37
I mineral water and I think that it's a good substitute for sodas but is this a healthy choice? I usually drink 1 small bottle of Pellegrino mineral water and I really enjoy it, it is very refreshing.
What do you guys think?
01-26-2016 12:58
01-26-2016 12:58
why wouldn't it be? aside from the minerals (which seem totally fine), there's really nothing else in it. is there something in particular that you're concerned about that makes you ask this question?
01-26-2016 15:10
01-26-2016 15:10
I did a quick Google search on the product, as i am not familiar with it, and from what i can see, the befits from it are good!
01-26-2016 15:16
01-26-2016 15:16
The only bad I could see would be if you have gastric problems with any carbonation.
Other than that, I personally hate the ones that come in a can because they tend to taste like aluminum, which is pretty gross and a little disturbing. Glass bottle is best.
01-27-2016 04:56
01-27-2016 22:09
01-27-2016 22:09
Yes, mineral water is a very healthy choice! It not only helps replace sodas by fulfilling a nice carbonation kick, but because it is an alkaline substance, it helps to balance out too much acidity in your body. I drink some every day!
01-28-2016 18:58
01-28-2016 18:58
I dont drink this but I drink a lot of Tonic Water. I just try to make sure it does not have a lot of sodium.
Mine has very little. some will contain a lot so its just something to watch for
Wendy | CA | Moto G6 Android
02-08-2016 03:32
