12-02-2020 13:09
12-02-2020 13:09
I am hoping that someone can ease my mind about my Food Plan choice - I have it set to Personalized which, of course, adds available calories as I burn/am more active. I like this b/c I DO get more hungry throughout the day and even though I don't eat ALL the calories it says I can, I do eat more than if I had it set at a stationary number (like 1600). Should I keep it at a set number or do you guys do well/are succesful eating with a personalized/adjusted Food Plan/Calorie goal?
Best Answer12-03-2020 21:00
12-03-2020 21:00
I work out of home so I don't go outside much, unless it's to run errands. I work out with strength and flexibility training regimen (tough one, doing contortion) 4-5 days a week, minimum an hour to 75 minutes each time. Do minimum 30 minutes cardio, even though I hate it.
Best Answer12-05-2020 02:43
12-05-2020 02:43
Thanks for the information
Best Answer12-05-2020 12:45
12-05-2020 12:45
To me, it sounds as though you are happy with the way you currently have it set-up. I'd give it a try and re-visit the decision in a couple of weeks to see how goal progress is going. If it's not working, tweak it. For myself, the opposite approach works best but I tend to be a planner. Remember, nothing is set in stone.
Best Answer12-07-2020 14:59
12-07-2020 14:59
I think whichever helps to stay to your goal is what you should stick with. what works for one, doesn't always work for someone else.
Elena | Pennsylvania
Best Answer01-02-2021 10:50
01-02-2021 10:50
how are ytou
Best Answer01-02-2021 10:51
01-02-2021 10:51
how are you
