04-23-2020 05:16
04-23-2020 05:16
To cut down on evening snacks, after supper I go floss and use mouthwash and that keeps me from wanting anything . . . Don't want to undo my dental hygiene . . . Works for me . . . And also when I crave a snack during the day, I simply chew gum . . .
05-14-2020 06:42
05-14-2020 06:42
Good ideas, @mtntopman . I’ve found that the less I snack (especially high carb snacks), the less I feel the need to snack. At the start of the “shelter in place” restrictions, I decided there would be no snacking after dinner. Then I switched to non-processed carbs for the rest of the day. I struggle with a compulsion to eat, eat, eat. But cutting back like this, has almost entirely eliminated that compulsion. Granted the first week was pretty difficult, but the rewards were worth it. I tried splurging a time or two, And the cravings came back immediately. It was not worth it.
Best Answer05-14-2020 17:39
05-14-2020 17:39
@SunsetRunnerit's worked for me . . . But I do eat sweets and when I do, I cut back on bread or potatoes . . . But the best thing is, I avg. over 40 miles a week walking and have for over 5 yrs. now .
05-15-2020 05:13
05-15-2020 05:13
Wow, @mtntopman ! Great job!
Best Answer05-26-2020 12:29 - edited 05-26-2020 12:32
I love this advice and I should DEFINITELY be more mindful of this. Typically when I'm having cravings they're for something sweet. I keep a bag of semi-sweet organic chocolate chips in the fridge and usually allowing myself only one does the trick because they're so sweet. Which works out because they're super low calorie!
05-30-2020 09:24
05-30-2020 18:04
05-30-2020 18:04
@Jessdavies Hello to you
Best Answer05-30-2020 18:06
05-30-2020 18:06
@Apple-Chips It works for me and has for years . . .
Best Answer05-31-2020 17:49
05-31-2020 17:49
New month..
New goals..
Best Answer05-14-2021 22:50
05-14-2021 22:50
You do it right, but it would make things better if you replaced the gum with dental floss.
05-16-2021 01:05
05-16-2021 01:05
Btw, what gum do you chew?
Best Answer05-16-2021 01:10
05-16-2021 01:10
That's pretty nice to follow the hygiene for your mouth. Before, I thought it is enough to brush the teeth two times per day. But then I started to have failed root canal symptoms. My dentist said that my dental tissue got weaker because I don't clean my mouth after eating snacks, but I was eating them a lot. So then, I decided to use Listerine all the time I am eating something. Also, I always use dental floss after the meal. So now I feel a big difference between now and before. My dental tissue became stronger, and I feel my mouth cleaner, without any extra smell that was always destroying my teeth.
05-17-2021 16:08
05-17-2021 16:08
