06-11-2020 12:17
06-11-2020 12:17
1/2 cup of Quinoa = 80 calories but when I used the digital scale to get a more accurate reading the weight was 70 grams which translated to 249 calories!!!
Does that seem right?
Do you go by the measurement or the weight?
Best Answer06-11-2020 13:38
06-11-2020 13:38
Hi @Carla123456 and welcome to the forums! Are you measuring/weighing cooked or uncooked quinoa? That will make a difference. You can google “quinoa, nutritional info” to get the official word on calories, etc.
Best Answer06-11-2020 14:13
06-11-2020 14:13
Hi!
Thanks for replying.
it’s cooked quinoa. The nutritional info on the package gave info based on 1/2 cup (I scanned the barcode for the Fitbit app) but then I weighed it and it put the gram info (edited the measurement on the Fitbit app) and it gave me a MUCH higher number.
weird
Best Answer06-17-2020 07:23
06-17-2020 07:23
Hi! Are you taking into account the weight of the cup when using the scale?
Best Answer06-17-2020 16:02
06-17-2020 16:02
half a cup is 64 grams, so there must have been something else in the cup or your scale may be off. When I measured and counted, I would use the label info to determine what calorie value is assigned for an amount. and then I would weigh to make sure I only had that amount. I wouldn't translate it to anything. So in your scenario a half cup is equal to 80 calories. I would measure out ounces equivalent to the half cup on my scale and log the 80 calories. That would be 2.25 ounces.
Elena | Pennsylvania
