04-27-2017 11:54
04-27-2017 11:54
Just wondering if anyone new of any good (free!) websites where you can type in a recipe, and it can give you the nutrition info per serving? I know the Weight Watchers website used to do that, but I don't have an account there anymore.
Thanks! 🙂
04-27-2017 14:07 - edited 04-27-2017 14:08
MyFitnessPal has a recipe option. It will also sync with Fitbit.
I've only tried it a few times, but basically you enter all the basic ingredients, the amount of servings and it will give you the calories and macros per serving. You can also edit your recipes which is very helpful if you make the same dish often but use less/more of something or add/remove ingredients the next time you make it.
There's also an "my meals" option which is very similar, but as far as I know you can't edit these (you can if you log it, though). Very quick and easy to log if you eat the same thing in the same quantity regularly, like if your go-to breakfast is a certain portion size of cereal with a certain portion size of milk. So instead of logging two items, you log the meal as a whole.
