08-03-2014 22:08
08-03-2014 22:08
Is there some reason why there isn't a "sync" button on the silent alarm page. the alarm doesn't "take" until the device is synced which, as far as I can tell, means going out of the program and having it find the device again. Makes no sense.
08-04-2014 19:34
08-04-2014 19:34
Not sure why there's no option on the alarm page itself, but maybe this can help?
After I set the alarms, if I go back to the device's page in the app (back one screen), I have the option to click a button at the bottom of my screen that says "sync now." The only reason I have to leave the app is if my bluetooth is turned off (which I do tend to do so it doesn't drain my battery).
09-24-2014 21:18
09-24-2014 21:18
Alarms ought to be on the Dashboard, perhaps as a tile, but certainly not a buch of clicks away on a setting menu. One should be able to see what alarms are set, and can be set.
Having to synch after changing an alarm or setting to new one may be a consequence of the platform Fitbit is running on; however, it doesn't have to be that way; and changing an alarm or/and setting a new one can be pushed to your device, they just need to implement the coding necessary.
Just as, when your Fitbit syuchronized as you wandered by the dongle, the browser display should not have to be manually refreshed.
This is just one more example of a really good product being pushed out in a hurry, and then the development team loses interest in the nitty gritty details, while working on the next "big" thing. That's a good recipe for eventual failure, as the unfinished detrius builds up, and people decide the gain is not worth the pain.
And just une mure egsample, whi is thure no spull chuck in this cumments windo. It's nut thut hurd tu du thut!
10-06-2014 19:02
10-06-2014 19:02
