02-03-2025 09:30
02-03-2025 09:30
Since the UI upgrade last year, the AM and PM selectors can easily move meaning that often my AM alarm is set at PM.
Can you look at rolling back the functionality to how it was before the UI change?
Thanks
Best Answer02-04-2025 06:44
02-04-2025 06:44
Hi, @msalib welcome to the community, if you would like to provide feedback or make a feature suggestion you can do so at Fitbit Community . Use the search bar to see if a previously posted suggestion meets with your approval & vote to make your voice heard. The board is monitored. You may find it easier to change your time settings in the Fitbit app on your phone to 24-hour notation. In the Fitbit app on your phone "Today" screen touch your icon in the top right corner>Fitbit Settings>Date, time & units>Clock display time>24 hour>return to the "Today screen & sync.
I hope this helps.
Cheers
Gr4ndp4 | UK
