Hey,
Any idea how to prevent accidental pauses on the Fitbit Inspire?
Trying to track some workouts. Tapping the screen anywhere wakes it up and a slight swipe will bring up the pause button along with another center tap pausing the workout. Really poor design it's so easy to pause a workout accidentally.
Any ideas on what I can do to prevent this from happening? Basically destroys the tracking for an entire workout when it happens.
Hi, @Bradleywpg, welcome to the community, try using the waterlock, this immobilises the touch screen until you unlock it using a firm double tap of the screen. While locked you can still auto-illuminate the screen by turning your wrist.
I hope this helps.
Cheers
Gr4ndp4 | UK
Wow so you can't actually even activate this mode after starting a custom workout... Unbelievable design.
When you turn it on it goes to the home screen and as soon as you turn it off you can't only reactivate it by going back into the setting screen which is inaccessible while a workout is active.
Hi, @Bradleywpg Have you tried simply covering your Inspire 3 with a wrist sweat band?
Cheers
Gr4ndp4 | UK
